no quiet am2 heatsinks?
badbadtz560
I just bought a zalman 7700alcu for my a64x2, but it doesn't have a useable bracket. It seems that zalman doesn't have anything am2 that would fit inside my microfly case. Can anyone recommend a good heatsink for my am2 socket?
I have a Freezer Pro 64 and I don't hear it over my two 120mm case fans..........for what it's worth :)
SCYTHE Mine for 35 bucks @ new egg.
i can barely hear it on my 4600.
idle 32C load 46ish.
are you guys sure these will fit in a microfly case tho? It's an SFF case that's about the same size as the q-pack or xpack or something?
Hmm... mine- probably not. The thing is huge. I have a Lian Li, and its like 2 inches from the window.
No wonder why the package has a picture of the freaking matterhorn on it. :eek:
Consider the OCZ Tempest, Zalman CNPS8000, or perhaps even a Coolermaster R120 WC system if you got the extra bucks.
there is also the Coolermaster Susurro and I think they have another slim case cooler.
AFAIK the cooling properties are kind of crappy but it stays very quiet.
