No power. What could be the cause?
darkego
Ok, kinda freaking out here. My dad just got home with my flash drive that I left at his office and I saved my homework on. I booted up my computer and went to print it and all of a sudden my mom decides I have to go get gas. I was pissed but I still shut my computer down normally. Nothing went strange with the shut down. Well her I am 15 home and I go to turn on my computer…. Nothing. No power up at all. not even for a second. Almost as in its not connected to a power outlet. How is this possible? I just moved some fans around about 2 days ago so I figured I knocked a connection lose… nope. Everything seems to be connected. Also tried a different power cable and a different outlet. So effen confused. My computer is not even 4 months old and now this? Any help at all? And no I don’t have a power supply to swap out Can you guy please help?
I have had the individual sockets on the power strip burn out. Try using a different outlet. Hope that helps :)
Edit: I dont smell any thing out of the oridinary.
One this strange happened that never happened before. Right before I hit the power button my finger snapped with static electricity along the metal on the side of the button… But this shouldn’t of done anything from the outside pf the case. Dont get it!
When there is no reasonable explaination, start with the basics. Is the circuit tripped at the breaker box, is the computer plugged into the wall socket, is the switch on the back of the PS in the right position, is the power cord secured in the back of the PS, is the harness secured in the mobo correctly? Clear all of that out of the way and then start with the comp parts themselves.
*Is the circuit tripped at the breaker box
- I wouldn’t think so seeing as my monitor ,boom box and light that are plugs into the same power strip are still working. Plus I have tried multiple outlets nothing.
*Is the computer plugged into the wall socket
- Tried straight into different outlets and a power strip, also have tried 2 different power cables.
*Is the switch on the back of the PS in the right position
- I’m not sure what is the “right position” is, but it is set to 115
*Is the power cord secured in the back of the PS
- Believe so, can see why it wouldn’t have been for either cord.
*Is the harness secured in the mobo correctly?
- Harness? I’m not sure what you mean. I think it’s mounted correctly, been operational for about 3 months.
Are you sure it was static electricity? It may be as simple as a broken switch. Follow the wires from the switch to your mobo header. Pull the 2 wires off where the switch connects, and careully short those to pins momentarily with a small screwdriver, jumper wire, paper clip, or whatever else you feel comfortable with.See if it fires up.
tryed it. Nothing. Computer just sits there dead >_<. the power suplie still has that light eletrical sound when you turn it on (maybe you know what im talking about) so it cant be that >_<
Please, dont say "can't". Even the most unlikely solutions often are the cure. Never assume anything until it's proven. If it were my box, at this juncture I would be trying a new power supply.
remotely possible, but you could have sent a static electricity surge coursing through the power switch wires right into the motherboard, killing it. I don't want to play doomsday sayer here, but if you felt that electrical static shock right before you turned it off, and you didn't do anything else physically to the computer, it's a good bet it's dead. Might as well stick a fork in it and get thee homework printed out elsewhere.
Who's the manufacture? Since it's only a few months old you should have a warranty on it still.
Try this, unplug the computer from the wall and hit the power switch to dump any remaining power. Then remove your cmos battery for about 10 minutes (or use the cmos jumper to clear it). Let it sit for a few hours then put everything back to normal and see if it will fire up.
Weird shit happens and this has fixed simular problems for me.
Well i felt it right befor i turned the computer on but same diffrence. And arnt computers pritty protected agenst static from the outside? Even then i would think it would take more then that to kill it woudent you think? The computer has been un pluged allday, and i dont think i have a light on my board telling me if its geting power. But like i said from the moment i turned it off, to the moment i turned it on, i diidnt do anything to it, and i havent been online with that pc. Tryed it agian just now and nothing >_<
Case and PSU - aspire
Mobo- Chaintech
Aspire is one lousy PSU. You've just been a victim of bad manufacturing. GG.
-J.
Mobo- Chaintech
Well, it sounds like you are going to have to get a crowbar out and pry open your wallet (or your dad's) and get a new power supply to test it with.
I was working on a lady's computer last week that did almost the same thing. It was working one day, shut it down, and then the next day when I tried to fire it up, the PSU would try to come on, and spin the case fans around 1-2 times, then cut out. Opened the case up and saw that it was a Powmax PSU... problem found :rolleyes: Replaced it with a good spare I had sitting around, and everything worked fine.
See, if that happened to me, i would be happy. Because then i would know its the PSU, but mine doesn’t even try to boot. just sites there an stares at me (figuratively speaking). I have a 350 psu but that would mean i would have to try to boot my system without my video card, and that wasa *&^% to put in, and im sure it would be the same to take out and put back in. Any sign of life would be nice but it does nothing.. arg. Day before Christmas eve and i haven’t been able to work on it. Is there a way i could of killed my mobo from the outside like Buckus said? Things i installed just 5 nights before was just a sound card thing that was part of the onboard sound to my mobo (I had to almost bend my case to get it in, maybe applied to much pressure?) and i moved some of my case fans around... STill looking for input from you guys thanks
