No power, no nothing!
ThrawnFile
I finally got every thing together for a new beast of a system.
Obligatory specs:
ASUS A8N-SLI
AMD 4000+
2gb OCZ 3200
2 74gb raptors
2 XFX 6800gt.s
All in a modded Lian-Li with enough fans that it sounds like a plane taking off.
At first the problems were just software. still can't get nvRaid to install with x64, and the drivers for SLI in the x64 windows don't work. But I can live with those quirks. But now for some reason I the damn thing wont power up. I had been using it earlier today, prepareing for a game and whatnot, and turned it off when I had to go back to work. Come home and hit the power button and nothing happens. No lights, no fans, no POST screen.
So I check the obvious, the power cord, UPS unit, take off the bezel and wiggle to power switch, check connections on the MB, try a differient power switch. Even go as far as shorting out the PSU and make sure it wasn't the problem. (PC power and cooling turbot cool 510 SLI). I stripped the MB down to just the proc and ram, with the green led on the board telling me that power was being fed to it and still no juice flowing.
So I'm at a loss, and quite irate that I've spent this much cash only to be left hanging in the end. If anyone has any ideas that I could try, before I start auctioning off the good hard ware, I'm all ears.
Ouchies,
if possible check the cpu and ram in another board and when you find they are good. send the MB back.
