No post or beeps when powering up!
ohkeykey
Ok i have
Aopen nck804 socket 939
2 512 mb ddr ram
500 watt psu
athalon 64
radeon 1300xpro
So the problem is when i power up the computer the fans and lights come on but no video or beeps. The mobo is new the psu is new and the RAM is good and the video card has been tested. I also have 2 CPUs and i have tried both. I have tried to boot without the CPU and i get one beep... I cannot figure out this problem and if there is anyone out there with any insight into this please feel free to leave a post
could be a dead mobo or possibly psu, but check that all power plugs are in the board including the secondary ones besides the main ATX power plug. i've made that mistake once and made a good fool of myself.
I have tried 3 different mobos 1 did nothing and the other 2 just give me fan and lights but no beeps
No post. No beeps.
1. tried several cpus- no post
2. using known good videocard.
3. tried using several MBs with no improvement.
4. ran PC without CPU. Got steady beeps.
5. Ram tested good.
6. New power supply.
What is left?
1. Take out everything and clean the insides of the case to see if there are extra metal or objects in the case. Please check your standoffs are all installed.
2. Check you heatsink/fan is installed correctly with thermal paste. A heat issue may be causeing a no post.
3. Is it possible to check your power supply or use a extra handy one? A bad rail(s) may be causing a partial power up.
4. Take out your dvd/cd drives. I had a no post before with a bad dvd rom.
5. Check if your brand of ram is compatible with your motherboards. Some ram works with some MBs and not with others.
