Spare-Flair
- Apr 4, 2003
Built a system for a friend and I insisted many times that he should get a new PSU but he said "it was okay" and re-use a 550W Antec Trio.
I just want to confirm if this is a PSU issue. If we can get the computer to turn on, it will be fine but if he shuts down, often he cannot get the computer to turn back on. There will be no response at all, the PSU fan won't even spin. The power on pins won't spark, etc.
As long as the two pins are bridged on the 24 pin connector, it should have some kind of response should it? I've seen PSUs turn on briefly and ground out when they find a fault in the system but the PSU won't turn on at all, as if there was no power at all (yes, did check if it was plugged in).
Is the power draw at power on significant? Is there a "hump" it has to get over for the PSU to be able to basically "turn over?" System is a 2500K on Gigabyte H67 chipset with an ASUS 2GB 5870 Matrix with 4 mechanical drives and an SSD. I'm pretty sure it's the PSU, but just wanted to make sure that this isn't something to do with the motherboard.
