No Post afer reseating waterblock
tpfaff
Like it says, I reseated the waterblock and now I get no video signal on the monitor, there are no bios beeps either, I took out the motherboard and I dont see any visible damage from overtightening or anything. I also tried to clear the cmos but it was a no go, tried a different monitor.... nothing. Did I crush something do to overtightening? Is my mobo dead for good? BTW I have a rev 1.0 GA-965p-DS3. Also I dont see how its possible that I overtightened it because there's washers in between everything that could contact the motherboard
I don't see how you might damage anything either. Pull out all the cards, memory and unhook HDs if they're connect via the mobo. Boot, any beeps? You should get beeps because of no memory. If not, either the mobo or CPU. Got a spare CPU to exchange?
I had this a few months back when using an Apogee GT. Wouldnt post for anything. Luckily I still had a spare motherboard and ram but it still wouldnt post in that set up. I didnt think I used much force but I guess I damaged the cpu. Its replacement works fine.
not necessarily, i doubt you damaged the cpu at all. my guess is that the cpu simply up and died. it happens, device will go for days and then just up and break, other times they will work for min, if it is under warrenty get the cpu replaced.. :)
Easy
Sounds like the problem I had with my first out of 4 DS3's. I didn't mess with the hardware at all, I just overclocked it after resetting the CMOS a few times trying to achieve a clock speed higher than 3.2 and it wouldn't post, boot, or even power up. I changed literally everything, got another DS3, same exact thing. Went through 2 more DS3's and then finally got an ASUS P5B-Deluxe. With the exact same hardware minus the motherboard, it worked fine.
