No multplier access above 12.5?!?
DaLurker
Well just installed my new Asus A7N8X-E Deluxe board, and I can't access the 14x multiplier that's default for my 2500+ XP. When I do that, it sets it to 6 (making the speed 800, instead of the 1800). Any ideas? I have the newest 1012 bios.
The stock multiplier for a 2500 is 11. 11x166 = 1833mhz. If you recently purchased your 2500 recently (as in less than a year ago), it is probably multiplier locked anyway. You will not be able to change it to anything that isn't 11. This generally isn't a problem, as most people overclock the Bartons with the fsb. 11x200 = 2200mhz is the cookie cutter overclock for these chips.
I used 12.5*166 for my friends barton core, when I built her computer. It worked fine.
I have that issue on my 2600+ non barton as well though, don't know why it happens.
the a7n8x series only supports 4 bit multiplier selection.. to access 13x and up, you'd need to do a pinmod, which im sure you could find if you searched the forum/google.
Whoops :p SOrry.. it's a Mobile.. and didn't realize it was only a 11 multi stock. The system picks it up as a 14multi stock. Go figure :p Anyways, thanks for the help, looks like 12.5 is the highest I can go without a pin mod. Time to pump that FSB :)
Btw, if my system just shuts off when I use 1.7 and up CPU voltage, is that a sign my PSU isn't handling the voltage?
