No More Green!?!
AaronP
So yeah, after 5 solid years of use, my monitor decided to stop showing all things green (as far as that being it's color) ANyone know how to fix that?
Sounds like it is time for a new monitor. If you can try and change the cable that you are using or upgrade you vid card drivers you never know it could be something simple like that.
Is it refillable??Maybe it ran out of green ink???:)
