No more 200fsb?
thebliX
Ok well i didnt know if this should go here, or in the memory section so, if it should be can a mod move it?
Ok, so i had an a7n8x deluxe, with some mushkin green 2700, wich would let me run at 200mhz with kinda loose timings. I recently got a DFI Infiniti, and can no longer do 200mhz, with any timings, at 3.3v. Now on my a7n8x-d i was using 2.8v. Could this effect anything? Ive tried 2 diff bios, 11/27 and 6/19. any help?
(i tried booting with 200fsb at 3-4-4-4-8 or something along those lines and could not)
Try moving the RAM sticks to different slots and make sure they're properly mounted and then see what happens, if that doesn't work then who knows, maybe you just got a bum motherboard?
It does happen you know...
