No MoBo Ethernet, help
Rossco
Using EPoX EP-9NPA3 Ultra w/Athlon 64 & ASUS EAX1600PRO & 1gigRAM
I can’t connect to Internet using MoBo Ethernet connection or using wireless PCI but I can if I use a USB wireless. Triple checked router and cables. Network Connections show both Local and wireless “connected”. Reloaded drivers, updated drivers, loaded LAN driver last, PCI 1394 works with external hard drive, I can ping IP/TCP Okay and the NIC/wireless Okay but can’t ping the router. I want to flash BIOS but can’t find it, EPoX site won’t download and don’t see it at the new company. Any ideas???
Same thing happened to me. I reinstalled the mobo drivers multiple times nothing worked. Reinstalled XP with drivers like normal and now they work.
