No frills power pc under $700?
timnewbie
Hey I was wondering if it's possible to get a pc(just tower and guts). For under $700, that'd be good for gaming, photo editing, and have upgradability in mind? I don't care about looks. Lights window kits and all that don't matter. Name brand dont matter. I don't plan on overclocking at all either(unless that is the cheaper route). The last system I built was a 2800 oc'ed to a 3200 system, but since then athlon64 has come out and i'm not sure whats the best way to go?
Im thinkin athlon 64, system pci-e? sata? just to have the option of upgrading in the future? Any info is good info, thanks in advance. I know I can look all this info up myself, but I like real reviews by people with experience. And the age ol question of intel or athlon?
Basically I just need input, on a good mobo/cpu/video card combo. I can pick out the rest myself.
One thing you might keep in mind, if you're thinking of not going brand name, is do not even consider going anything but brand name on the power supply. PSU is the most improtant part of your system, don't skimp on it. Doesn't matter if it's a $5,000 rig or a $200 rig, never buy generic with PSU's (and RAM, but especially power supplys).
Just thought I'd point that out to you. :)
really? I guess its one users opinion vs another, which is basically what I am asking for. The reason I say this is because, I bought a Antec trueblue 480 psu and it popped the first time I plugged it in. However my 500 watt $29 psu I had, has worked and worked perfectly for months now. Ram, if I don't plan on overclocking it why go expensive? Don't they all use samsung chips anyways and just slap their own name on it. However for my current system I did buy the corsair low latency memory. Anyways, any reccomendations?
Well, I'm not saying all brand name PSU's are great and all generics are worthless. It's just that the brand name ones do fail a lot less, and usually put out more wattage. A 300 watt Fortron power supply will most likely put out more actual watts than a 600 watt generic PSU. Also the voltage rails are usually more stable, which is still important even if you're not overclocking (the more unstable the rails are, the more likely you'll have hang ups, etc.).
As far as RAM goes, the big brand names (Mushkin, Corsair, Crucial, etc.) usually have less problems (ie, errors in MemTest86) than generic RAM. Even if they use the same chips, there's other factors, such as PCB quality that can cause differences. With RAM it's usually not a big deal, because the brand names are usually the same price as the generic brands anyway.
I could be wrong, but I'm sure as more people reply it'll show that the general opinion is that on these two (RAM and PSU), brand name is usually best. Or, of course, people could just randomly start flaming me calling me a stupid noob. Either way, good luck with the system man. :p
