No-Frills Average Mobo Recommendations Please...
Sancti0n
I have the following:
Core 2 Duo Extreme
4 GB Corsair Dominator Ram
3 WD 75 GB Raptor SATA HDD
1 X-Fi Soundcard
2 8800 GTX OC Vidcard
Vista Ultimate 64
This was all mounted and working on an Abit IN9 32X-MAX mobo, which in turn was mounted on a tech station. Well the mobo finally gave up the ghost and I gotta get a new one.
Another IN9 is out of the questione (it's been discontinued, and the refurbs cost WAY too much for a refurb).
I'm looking to put all of the above mentioned hardware into a new mobo. It will also be sitting on a tech station. The tech station is in another room so noise is not an issue for me. Also, i'll be using a stock heatsink/fan for cooling.
Here's the thing, I can't afford another multi-hundred dollar mobo. I want it to be able to run both of my vid cards in sli, but other than that I don't need any special bells or whistles. I'll be running everything at stock speeds, no overclocking at all (I know, most likely the wrong forum to say those words lol, sorry about that).
I've always gone with either Asus or Abit in the past, but i'm not hung up on brands (can't afford that anymore). I haven't really been keeping up with motherboards for the past year or so (an age in PC terms). Can somebody recommend a good no-frills board that will run steady at stock speeds AND doesn't cost a lot?
As always, thanks to everybody for your time and whatever help you can provide :)
I've heard good things about the 750i chipsets if you want to continue using SLI without breaking the bank, the FTW is supposed to be a pretty solid board, but here are some boards to check out
XFX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813141016
EVGA
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188033
EVGA FTW
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188026
and search results if you need them
http://www.newegg.com/Product/Produ...1&bop=And&ActiveSearchResult=True&Order=PRICE
Thanks guys :)
That EVGA board does look nice (and the price is certainly right). My only concern is one "con" written by one of the reviewers:
"...Cons: Nvidia Network Controller off the install disk. Time Warner as my ISP, after installing this feature it conflicted with my ISP service. Time Warner line tested me, and it noted a conflict ( on their end ) naming this Network controller installation! I had no IP, no acees what so ever. be careful when installing this from the install disk!...".
I also have Time Warner. Has anybody heard anything else about what this guy is saying? Is he "just lucky", or is this a known problem? Is there a fix if it is a known problem?
