xmetal2001
- Oct 10, 2002
Yesterday I looked down at my computer and noticed the fan on the northbridge on my motherboard wasn't spinning. I took it off and examined it and found it was cracked, tried unsuccessfully to fix it.
My motherboard is a Abit IC7-G. I am not overclocking.
Can i run with just passive cooling on the northbridge until i can replace the fan? Also, in order to get off the fan i had to remove the heatsink. When i put it back on i suppose the stock thermal pad isn't making as good of contact as before, probably not a problem usually but if i'm running without a fan on the heatsink will it be a problem. Unfortunately i dont have any thermal compound.
The side fan on my case seems to blow almost right on the heatsink, but its a good distance away, still I suppose it would help. I dont want to harm my motherboard, is it safe to run until i can replace the fan?
Also, assuming it is ok to just use passive, should I stop things like Folding@home until i get a fan for it, or does that not matter.
