No DVI signal during POST with 2001fp
che
Hey guys, need some of your knowledge...
Got a Dell 2001fp today and have it hooked up to the DVI connection on my BFG 5900, problem is i'm not getting any DVI signal during POST (says 'cannot display this mode').
As soon as it loads to the XP log-in screen I get a signal and everything is fine, but I wan't a signal during POST so I can see BIOS and such. I tried with the VGA connection and it shows everything fine from start-up on.
I loaded the newest video drivers for my card and installed the monitor driver also.
My system:
Abit NF7-S ref 1.1
2400xp
1gig ram
BFG 5900
Any ideas? Thanks in advance
Che
maybe an issue with the interpolation of significantly smaller than native rez resolution. you could lower windows resolution to like 640 by 480 or 800x600 and make sure it is at least functioning properly.
Not much help, but all I can say is that I'm able to see POST on my 2001FP via DVI and have been able to on both a 9800XT and 6800GT. I also am able to see it if the 2001FP is DVI alone, and also on both monitors if I have another screen attached to the VGA port.
I'd try another video card, even if that means taking the 2001FP over to a friend's house, or even (dare I say it) down to CompUSA. Just explain that you're trying to diagnose your videocard (that you bought from them, of course), not the display.
I experienced a similar problem with my secondary computer (AOpen XC Cube EZ65) using Club 3D Radeon 9200 and Dell 2001FP. The card wouldn't output signal via DVI before Windows had been loaded. Also the card couldn't output 1600x1200 via DVI even with reduced timings while 1280x1024 and lower worked fine. There were absolutely no problems using analog D-SUB output.
I tested the card at work with several different computers and panels (also non-Dells) using DVI input and couldn't get POST info or bios screen in any of them. Finally I exchanged the card to a Sapphire one. The Sapphire could display POST information on some panels, but not all (including my 2001FP). Again the D-SUB output was flawless. I exchanged the Sapphire to a Club 3D 9600 Pro and it worked perfectly.
I guess that some card manufacturers probably use poor quality (=cheap) DVI transmitters on certain models, that can cause these kind of problems with panels that are "sensitive" to signal quality fluctuation.
Yea have the same problem.. got a 5900 too.. used 9600xt for a while and that had signal on dvi on post.. Ive been thinking if it has something to do with using dual monitors, what monitor is primary etc.. havent bothered trying much tho..
I have sorta the same problem.. If i turn on the computer and then turn the monitor on immediately after, alot of the time i get no video at all ( says dvi-d cannot display this mode) or something similar. i can turn the monitor off/ on and it works fine. it only does this when i turn the monitor on immediately after hte computer.. if i turn the pc on and wait like 5 seconds its fine :confused:
Thanks for the responses guys, at this point i'm guessing it is the vid card more than likely. I just don't want it to be the monitor b/c this thing is flawless (no dead pixels or bad backlight).
I've got an old geforce 3 around here somewhere, I'll try that and see what happens.
Sorry for bumping this but just out of curiosity I checked some stuff.. and I might have a reason for the problem.
Theres alot of different DVI connectors, DVI-I single/dual DVI-D single/dual and DVI-A, I checked a long time ago if my gffx 5900 had DVI-D connector which would have explained why it didnt show any picture (DVI-D is digital only while DVI-I is both digital and analog) but that wasnt the case. This time I checked instead how the cable bundled with the 2001FP looks like.. and that however, IS a DVI-D cable..
Im guessing older nvidia cards (prior to the 6xxx series) wasnt able to send digital signals before the drivers kicked in, while ATI was able to accomplish this in the radeon 9xxx series or maybe earlier.
This however still doesnt solve any problems, you might think just buying a new DVI-I cable would, unfortuneley thats a no-go, the DVI contact on the 2001FP is a DVI-D dual link, a DVI-I wouldnt even fit.
The only solution I can think of (which isnt even a very good one) if you dont want to use both the D-SUB (VGA) and DVI output on your vid card or if you only have a DVI output is to build a adapter that seperates the analog and the digital signals in a DVI-I cable and outputs the analog signals to a D-SUB connector and the digital signals to a DVI-D connector.. its an option but a really complicated one.. and you would still have to switch between the modes on your screen when rebooting etc.
http://www20.graphics.tomshardware.com/graphic/20041129/tft_connection-07.html
theres some info on the connectors and would also help you get going if you wanna make such an adapter
Sorry can't offer any advice.... but unless it's something specific to the 2001fp, a DVI dual-link port is the "universal acceptor" and can work off analog, digital, and dual type cables. Furthermore, all digital cables will fit one another, it's the type of signal running through them that designates the prefix -I, -D, etc. Take a look at Toms hardware guide for the low down.
as I stated, theres dual link -I and -D, -I can use both analog and digital while -D is just for digital, and no, all DVI cables will not work with eachother, the connector on the 2001FP is missing the 4 out of 5 of the analog ports (analog ground is still there) so there isnt holes for DVI-I cables.. I'll take a pic if you want :)
I dont know what exactly causes it, but i do know that certain 5900/5950 bios's allow for the dvi to post while others dont. My asus 5900 with the asus bios posts on both outputs (dual monitors) but when i flashed to a BFG bios that stopped and now i only get the post screen from my vga monitor. So there is a way to do it
Well since we are on the subject of cables, my DVI-D cable has 1 recessed pin on both ends, is this normal? It was provided by viewsonic with my lcd.
