JustReason
razor1 is my Lover
- Oct 31, 2015
then, pray tell, what is your point?Of course this discussion about dies is irrelevant for final users, as I wrote in a former post:
actually looks more like not making a DIRECT statement as to quell any real argument or debate, so when he LOOKS to be proven wrong or bias he can then claim something else. Obfuscate, obfuscate...post countI mean he says something then proves what he says does not matter then replies anyway as if it mattered.
They are probably not functioning dies.
At this point I think it's likely that the worst chips on amd ryzen wafers are being used as the supports for ThreadRipper. Though I can't comment on how much worse they are xompared to 4 or 6 core variants.
No it isn't otherwise I and others wouldn't have to ask.The point is clearly stated on my former posts in this thread.
And that is the point, as you stated.Why are you bothering with him, even Dan told him no one gives a shit and it's splitting hairs on a terminology. You know he will spin everything to make it sound bad for AMD, no matter where the actual truth may be.
Is it possible for regular (very talented obviously) human beings to hack a die off one substrate onto another? They're placed on a ball grid array, aren't they? And can we reverse engineer which traces go where?
Why bother? There is no way to get it to work if you even had the means. Threadripper and x399 do not have the electrical connections nor was this socket ever made to have 4 dies active. In other words you'd have to connect them to the Infinity Fabric, and um who has the ability to do that? If anyone could enable 4 dies on this socket, it is going to be by AMD.
I just don't get the fascination with this.
My motives are purely academic. I'm not that fascinated, I realize this is not the Athlon II anymore.
Just wanted to know if one can change the dies around the board to check if they're broken. I know nothing about the infinity fabric but I'll google![]()
You make it sound like a problem. It obviously isn't as the other 2 dies, whatever their makeup, change nothing as far as performance.
You said AMD lied and no where in any report of statements MADE by AMD do they lie.
Update: AMD has clarified that two of the four silicon die are 'dummy' blanks rather than disabled Ryzen chips. They are included for structural stability.
AMD responded that two of the die on shipping Threadripper models are not the same as those Der8auer found in the engineering sample - the additional two die are "dummy" die that the company uses to provide structural stability for the package.
How far would you go to prove a point? Well, the overclocker and CPU delidding expert der8auer has decided to put AMD's "Dummy Dies" claim to the test, to find out once and for all whether or not AMD is using failed/defective Ryzen dies or silicon spacers.
He found retail ThreadRipper has four Ryzen dies, two enabled and two disabled, just as the engineering sample. AMD lied. Period.
I am just gonna chock this one up to you're being terribad at language interpretation. Der8hauer is a MORON then, apparently he too has comprehension skills. At no point in AMDs statement do they speak to the chemical/physical makeup of the dummy dies just that they are structural support and therefore lack the necessary connections to be "turned on". He inferred they meant not dies of any sort and therefore wasted his money proving nothing in contrast to what he knew before and thusly wrangled a few of you gullible types in.I know that this doesn't change performance. I stated in more than one post that "this discussion about dies is irrelevant for final users," If you could read what I wrote...
Precisely der8hauer purchased a retail chip and dismantled to check if AMD was lying or not. He found that AMD lied. Relevant quotes have also been given in this thread. I will repeat some of the quotes published in the press for you:
They probably have non-functioning memory controllers or something else that makes them completely unusable.
According to AMD, they have no traces beyond the dies themselves. They do not and cannot be connected to anything?
Gideon said: ↑
What gives you that impression? I have no preference between either manufacturer. I've often had more Intel CPUs because of AMD's half-assed platforms and Intel having better performance over most of the last two decades I've been involved in the computing industry. Price / performance ratio's aside, these are facts which can be proven. AMD's platforms have often performed worse in some ways, were less flexible, or were more problematic. I've pointed out the reasons for this many times. AMD's CPU's over the last 10 years were lacking compared to their Intel counterparts. Again, this isn't bias or fluff, it's fact. How does this make me biased?
I've also been a fan of Ryzen / Threadripper and I've said as much in many threads. Yes, the platform annoys me with memory compatibility issues and a few other problems, but I'm far more pissed off at Intel right now for it's VROC and recent high end CPU pricing fuckery. I like and have liked products produced by both companies. I think both can be bone headed at times and call each of them out on things I do not like. It just happens to be that AMD has had a worse track record over the last couple of decades. That's not bias, that's just how it is.
I was not talking to you Dan, I was talking about Juanrga. I agreed with your assertion that AMD lied an it's some kind of big deal is stupid. You and I may not always agree on things but my comment was not about you. Most times I mention him by name I get a warning so I tend not to use Juanrga name, just a FYI.
no beuno.
We all know this. He and I were speculating how dies are selected to be the support dies.
der8hauer found 1 cpu had 4 ryzen dies, that does not automatically mean that all TR cpu's have 4 ryzen dies. Was it a retail stepping ES that was remarked? Are some shipping with blanks and some shipping with defective CCX's?
Since they can't be activated in any way the whole thread is pointless bollocks. AMD hater's will use this as evidence that AMD lied about the origins of the cpu, AMD fanboys are looking for a cheap pencil mod for extra cores.
When TR gets more cores it will be on 2 dies using Zen+/Zen2 or whatever its called this week, using the 7nm process
then stop replying. there is nothing more to discuss anyways...This thread is irrelevant for final users, as I stated a couple of times, it is relevant for certain other people that is neither a fanboy nor a hater.
Maybe not 4 GHz, but it should be easier for them to achieve higher clocks than Intel's big monolithic dies. And the cores are much more efficient in the lower 3.X range.
That doesn't seem likely if there are always the same two functional cores in TR.
