no display during POST on 2005FP
mutthead21
Hey everyone,
My 2005FPW won't display anything during the POST, it did initially and now after a fresh install of the latest Omega drivers, I get nothing until windows is loaded. tested it on the CRT and it's fine - what's the go? Can anyone help me?
thx.
It's most likely your video card not outputting the POST to the DVI port, if that's what you're using (since the CRT uses the analog D-Sub). Check it out with your video card's manufacturer.
It's very easy to diagnose this problem. Just connect your 2005FPW to the VGA input, and switch to VGA mode, then see if the POST shows up.
if vga works and dvi dosen't, it means the problem is your videocard...flashing videocard bios may work.
in my case, i just bought a new one. :)
