SilverMK3 said:It only relates to connecting DVD players, consoles, or other Dolby Digital/DTS products to your speakers.
If you have a device that outputs a Dolby Digital or DTS stream (such as a SoundStorm motherboard) then I recommend getting the Klipsch DD-5.1 external decoder
It means that any Dolby Digital or dts decoding must get done before it leaves the computer.Delltron said:What exactly does this mean? Does it mean that i cannot play movies/games in superb surround, or does it only relate to plugging a dvd player or whatnot to my computer? Thanks
As "no digital decoder" implies, in the case of the Promedia 5.1 Ultras, it simply means that the speaker set itself lacks digital-to-analog conversion internally. The Promedia 5.1 Ultras, like most other high-performance multimedia loudspeakers, accept only analog audio connections. A built-in DAC would have forced the manufacturer to cheap out on all of the other parts of the speakers, since quality DACs and quality loudspeaker innards are expensive.Delltron said:What exactly does this mean? Does it mean that i cannot play movies/games in superb surround, or does it only relate to plugging a dvd player or whatnot to my computer? Thanks
