No component inputs on 2005FPW?
i'd like component hookups too, but i'd rather not use the DVI port, that is being used on my computer, i'd like to hook my xbox up to something better than the S-video....there is only 1 DVI input :(
I was thinking about doing this, too. What you want is a component to VGA transducer. The one that most people use is from vDigi. It also comes with the component cables for XBOX. This way you can hook your computer and XBOX up to the monitor at the same time. I don't think the component cable will work with XBOX 360 though.
JayD is right but its a transcoder, not transducer. The 2005fpw does not have component inputs but that v-digi will convert component to vga which you can connect to the panel.
I am confused. Do you want to hook up like DVD player and XBOX to 2005FPW or do you want to hook your computer to an HDTV? Everyone's suggestion is showing the DVI to HDTV.
