No bottleneck, new build for gaming
Discussion in 'General Hardware' started by I3eyond, Jun 5, 2018.
  1. I3eyond
    I3eyond Gawd
    914
    Jan 14, 2006
    Gaming. BF5, WoW, Overwatch, PUBG, etc.
    $2,000 before tax/shipping
    NC
    Case, motherboard, CPU, memory, GPU, PSU (I know everything isn't a valid answer, but so is
    n/a
    6) Will you be overclocking?
    No.
    3840 X 1080 ... 49" 144Hz
    Now, or wait for 1100 series?
    9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
    Reliability, stability, plenty of USB
    10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
    No ~ Will need Windows 10.
    I think what this ultimately comes down to is do~
    -Do I wait for the 1100 series to launch?
    -Are there any new CPU platforms launching to wait on?
    I want a rig that nothing will bottleneck anything at 144Hz at 3840 X 1080.
    Thanks for the help!
    -I3
  2. SvenBent
    SvenBent 2[H]4U
    2,221
    Sep 13, 2008
    you will always have a bottlenekc,
    if not you would have infinite fps.
    You could argue it could be possible to create a non bottleneck system for a very specific application in a veruy specific settings. but ther will be a bottleneck for other software somewhere in the system and the system would be unable to upgrade ( since that would create a bottlenck)
    TBH i dont think you understand the term bottleneck correctly
  3. I3eyond
    I3eyond Gawd
    914
    Jan 14, 2006
    When I say bottleneck, I mean no skimping on RAM, or another part, that would bottleneck something else within the build.
  4. I3eyond
    I3eyond Gawd
    914
    Jan 14, 2006
    I have a monitor, but looking at getting the 49" Ultrawide Samsung.
    Already have a kb/mouse from Logitech.
    For storage I would like a couple of large SSDs.
    Should I juice up the power supply some to have SLI capability in future?
    Thanks!
    ~i3
  5. vick1000
    vick1000 [H]ard|Gawd
    1,872
    Sep 15, 2007
  6. Skillz
    Skillz [H]ard DCOTY 2017
    21,237
    Aug 14, 2004
    If you arent going to SLI now then you won't later. A single card will most likely be a better value and better performance by the time you decide to.
  7. SvenBent
    SvenBent 2[H]4U
    2,221
    Sep 13, 2008
    Tou have to realize that that question itself is built on flawed logic. as bottleneck is not imposed by your hardware alone but by your software and how it utilizes your hardware
    aka the same machine will be CPU bottlenecked with software and GPU bottleneck in software B and lack ram in software C
    You software determines what will be the bottleneck in your system. so without the proper information you question ins impossible to correctly answer
    and again: you will always have one part that bottlenecks another unless you have infinity performance
    You question is just not put up right to be answered correctly.
    A better way to approuch it would to be more worried about the speed of the system in what you want to use it for.
  8. vick1000
    1,872
    Sep 15, 2007
    The OP clearly listed the software the build is intended for.
    For $2K without a monitor, bottle necks are not an issue, top GPU and CPU with 16GB of fast RAM and PCIe SSD cover it.
    I3eyond likes this.
  9. I3eyond
    I3eyond Gawd
    914
    Jan 14, 2006
    Thank you sir. Is there any difference in performance in a PCIe SSD and a 2.5?
  10. HiryuuX
    HiryuuX Limp Gawd
    208
    Jul 16, 2017
    You have a lot of options for under $2000, but here's one for ya.
    https://pcpartpicker.com/list/k3YWcY
    8700k + ML240L AIO (front mount on case) + Z370 Killer SLI/ac motherboard + 16GB DDR4 3000 RAM + 1TB SSD MX500 (selected for M.2, warranty, speed), 1080 Ti SC Black Edition, Phanteks P400 TG case (tons of good options here - Meshify C TG, S340 Elite, H500, etc), EVGA G3 750W 80+ Gold fully modular PSU (it's on sale at Amazon so why not), and a W10 key.
    Technically you probably wouldn't need an 8700k at such a high resolution, but if you are only gaming then Intel is your best option. Ryzen will be a tad behind, while offering more cores/threads/value for the same dollar amount. That said you could get a Ryzen 2700/2700X + X470 setup and run the stock cooler to save $100-150ish.
    horrorshow likes this.
