Freaking great. So I put my DS3, e6400, and new Patriot ram in, and it finally boots after wiggling around the chassis cables a bit. I get into the BIOS and check to see that everything is ok. After that I rebooted and tested moving the FSB up to get it to 2.5ghz and with the ram not even hitting default ram speed, and it doesnt reboot. Nothing happens when I it the power button, tried resetting the CMOS by removing the battery for a few minutes, even changed out the battery, double checked everything.
I don't have a jumper to jump the CMOS pins either, but removing the battery should do something. I have tried everything I can think of. I need help because I am using this build on a recording session later tonight!!!
EDIT/UPDATE: Ok, so I upped the voltage to 1.4 and the ram voltage to 2.2, and did an Orthos Run at 3.4ghz . It failed after 10 minutes so I restarted. I got an extended bios beep and then it turned on and off several times on its own.
After it stopped, the computer would not turn on again. I jumped the CMOS pins with a screw driver, removed and installed the CMOS battery with a 1 minute wait in between, tried several RAM configs... and.... nothing. no power at all. What on earth is this motherboards problem? The initial problem for this thread just randomly went away and it powered up after a bit of time.
