I built this PC a while back that worked fine, but not sure what I did, but when I switch it on, I get nothing. The power is supplied to the mother board (it has a LED to warn it got power) and the HD spins up, so does the fan.
But there is no signal to the Monitor and I think the BIOS does not even get displayed because if it was the graphics, you'd hear the HD booting up windows.
I leave this on for some hours, and hit reset... I don't do nothing... and it boots up fine, BIOS gets displayed and it works!!! A friend said it may just be a dry connection.
Now after several months, it stops working. So I buy a new mother board, new graphics card and memory... still the same thing.
Nothing gets displayed, not even the BIOS. I've tried a new PSU, but still nothing.
So the only thing left is the CPU. Now before I spend any more money... can the CPU be the problem??
I heard that if the motherboard touches the case, it sometimes prevent it from booting, but I'm sure it is not this.
Anyone any ideas before I spash out for a new CPU?
