Mindoculus
- Jun 2, 2003
just finished a fresh re-install of windows over partitions plagued with malware.
thanks to those here who helped with that.
i combed through a few of these threads and found similar troubles which i have resolved.
i had accidentally created a dual boot (C and E) in trying to remove the malware. both drives booted XP. tweaked boot.ini to eliminate redundancy (C). tried to format the same drive (C) i had eliminated off boot with partition magic, but PT wouldn't/coudln't do so.
re-ordered optical drive config via bios to boot off CD. re-installed XP. now OS wont auto-detect cable modem off USB.
this is a minor issue, comparatively speaking. i think i've recovered well off the malware attack and know that i will soon have a clean, smoothly functioning OS. thanks again to all who helped.
