No Audio with HDMI?
martinth
Hey guys, I have a problem.
1) I have a Samsung LN46B640 TV
2) I have a Samsung Z320 TV Entertainment System.
3) I have a Comcast Digital HD Cable Box
4) I have a Satelite Box that's hooked up to my tv via those Coaxial Cable.
My current setup is like this.
The Comcast HD box is connected though the TV via HDMI cable.
The Satelite Box is connected through the tv via Coaxial Cable
The entertaiment system is connected to the TV via HDMI cable.
What I want?
I want all my sound (DVD, Comcast HD, Satelite) to come through the entertainment system speakers.
Currently...only the DVD sound comes through the entertainment system speakers.
The other two, the sound comes through the regular tv speakers.
Btw, the two my samsung TV/DVD system both have the AnyNet+ system running.
thanks guy.
no going to happen, that DVD/AVR thing has no HDMI input...
it doesnt even have SPDIF, no go. you are stuck with DVD through the speakers and STB audio through the TV.
you need a REAL AVR that decodes HDMI audio, not all that have HDMI inputs decode the audio either.
the first review on BB site:
Customer Rating 5.0 5 This is a great Value with great sound. 12/16/2009
By Michael1376 from Humble, TX Read all my reviews
Value for Price 5.0 5 Sound Quality 5.0 5 Ease of Set Up 5.0 5 Appearance 5.0 5
What's great about it: Simple set up and great sound
What's not so great: no inputs for playing sound from regular TV
"This was a sinch to set up. Just plug in the sensor where your plan to vie the screen and the unit sets itself up automatically. The rear speakers function exactly the way it should. The fan in the rear receiver is a little loud but it is not noticable always. I love the look and design, small unit with big sound. The FM tuner sounds terrific. You can even set up your own wallpapers and listen to your music via USB or hard drive. Highly recomend this. I bought the dynex 32" LCD and all my copied movies look and sound great."
Would you recommend this product to a friend?: Yes
I got it fixed guys.
I needed to buy a Digital Optical Cable and then hook up my entertaiment system to teh tv with it.
