No 4pin on the PSU
I believe the eight pin connector is capable of coming apart to two fours and you can just plug one of the ends to your motherboard.
This.. The 6 pin should be a pcie. Not what you want at all. Its an 8 pin that comes apart in the middle
Weird, never seen that before. I'm trying to help a friend across the country put his stuff together and he's a complete novice at this stuff. So he won't catch little details like that, this is his first PC build, and I figured I'd be able to walk him through it.
Turns out that was the problem, and everything works now. Thanks for pointing that out, I'll keep that in mind.
