Ninja side panel, problem, need suggestions
Tengis
Alright, first off... this picture is of the "basic" cutout that I scanned on my scanner... :D. Ive actually cleaned this up extremely well, added tons of detail to the actual ninja part of the cutout... and it looks great.
Problem.
For some reason, during the entire process, I didnt realise one thing. I was cutting this for the RIGHT sidepanel, not the left. The entire thing is upside down.
Solution.
Cut out the ninja, and use the squary window for an nice etch?
Cut out the ninja, then make one out of sheet metal to go over the hole in aprox. the same spot it was before it was cut out?
I had some other ideas, but I dont like most of them.
My vote? You're screwed.
Seriously though, I dunno what you can do to fix it other than cut out the whole thing and make it a square window that shows nothing but the back of the motherboard tray. Myabe you could put some modder's mesh in it instead of being a plain window?
Or you could cut the same ninja in a differant pose for the left side, use a frosted peice of plexi for the right side, and throw a light behind that one, and have 2 ninjas on both sides. Oh and maybe even cut some throwing star windows in the top part of the box... or throwing star shaped fan grills..........sweet
Im already "done" with the mod for the most part, as soon as I get my first paycheck from my new job Im going to buy all of the little things that I need to finish it. Im also gonna grab a digicam.
Im very pleased with this case, I think it kicks ass.
Im gonna etch this... I think it looks really nice....
Ill find somthing to fill in the upper left part of it...
