NINJA PLUS REV B.
sulakoes
Hi, I buy a new a new Ninja Plus (Revision B). I´ll try to install onto Asus
P5WDG2 WS Professional,but I can see that the mounting bracket supplied touch
the capacitors. Is Ninja Plus Rev.2 compatible with my motherboard? the capacitors can broke down by weight, heat or something similar?
Thank you for uor help.-
I have an Intel Bad Axe 2 board and have noticed that the Scythe Ninja Rev B touches the capacitors next to the CPU as well. Everything seems to work, but I'd like it better if there was more clearance. Plus the Intel-designed plastic anchors seem barely adequate to hold such a massive heatsink in place.
