the nickel will allow you to transfer more heat to the water. I personally like to be able to see the water flow so I use the poly.
letsmod and others who don't know/haven't seen what you meant by "top" thought/would think of "top" as the non-copper piece that seals the block.http://www.jab-tech.com/xcart/product_images/detailed/d_4070.jpg
http://www.jab-tech.com/xcart/product_images/detailed/d_4066.jpg
Wouldnt you be able to see the water in both?
