Nice tip on epoxy for ram sinks
[RIP]Zeus
i been doing this for about a week now for my vid cards. the epoxy you get from articsliver really WORKS...hehe well if you put a bit of AS3 or AS5 in the mix it will actully make it easiser to get the ram sinks off i been doing some testing with it and it seems to work ALOT better then just as epoxy. also temps have been down by 3F degrees on the ram. so if you guys want to give it a go. but don't PUT to much AS3 or 5 in the mix or it will not stay on..
ya that what i do
and to get it off you use the dust spray and freeze them off
