Hostile_Monk said:Nice. I got a 6144 with my current rig.![]()
eloj said:How about that oggenc/lancer run? You need:
1. A RIFF/WAVE of your choice (ripped from CD, presumably)
2. http://homepage3.nifty.com/blacksword/oggenc283_sse3mt_lancer20060811.zip
3. oggenc2 -q 5 filename.wav
4. Post output.
Dare to be first.
vlado said:Hi could you try playing apple quick time hd video h.264 1080p at stock speed. I'm interested in the CPU utilization. And try it if you could with and without support from the GPU.![]()
vlado said:Thanks in advance.
I've been looking for this info but now every body is interested in OC which is normal but I can't wait.
Do you now how to switch off Purevideo? I don't know but maybe deinstaling nvidia driver could do.
That small feature is turned off when you overclock.sman262 said:
alik4041 said:That small feature is turned off when you overclock.
Your right i have seen this too , its something to do with the multiplier sometimes missing its clock.sman262 said:lol WTF, so 2 minutes later i check cpu-z agian and i get this
i dont know what the heck is going on, also if i use like sys tool, or intel desktop utilities, it will vary back and forth as well, very weird.
Agree with you very much , the boards are not that bad which are out there, they do peroform very well but there is other things i would also like to see on the board.adrift02 said:I like the pics. At least I can look at them and pretend until my grear arrives. Unfortunatly I cannot help but wait out the mobo scene until the 590's hit. Congrats and good choice on ur HD
P.S. That ram was my other choice but I got the gskills F2-6400PHU2-2GBHZ on sale instead. Let us know how it overclocks! Also what mobo is that? If u could, try and give us its max fsb. Depending on how overclockable the 590's end up being, I may get a intel 975x yet (no sli).
vlado said:This is what I found:
http://www.teamgroup.com.tw/forums/showthread.php?t=991
Also if you whant to go extreme and want to increase DDR voltage more than 2.2v this may help:
http://www.xtremesystems.org/forums/showthread.php?p=1460666#post1460666
vlado said:This is 17% OC at low vcore. Congratulations!
What are the temps?
I'm still waiting for you to test the CPU load in playin HD (h.264 1080p) video. Try it with and without OC and with and without Nvidia drivers for the GPU please. But if you do not have time do what you can but gime some info. Screen shot of the task manager will be good.![]()
What kind of corsair memory is that? is it c3? c4?sman262 said:yea, thanks for the reality check, lol.
i still would like to see if lapping could and or would do anything
cas of 4alik4041 said:What kind of corsair memory is that? is it c3? c4?
