Would having a dedicated NIC help reduce my ping latency? As opposed to the onboard?
My specs EVGA 680I, E6420, Win XP, 9800GTX.
I only play COD 2-WAW"5"
Probably not by much if anything at all. The problem is going to be with your network connection or your ISP. There is probably little to nothing you can do about it unless you switch ISP's. I'd call your ISP and see what the deal is before doing anything else.
