Nibitor BIOS editor and 7900GT
DemoMode
I noticed that Nibitor can read the stock volts from my inno3d 7900GT and it seems i can change the voltages there but i didnt bother reflashing as im afraid i might mes-up the card, would it also be possible to control the voltages via bios ?
Unlike the 7800 series, you cannot change the voltages in the BIOS on the 7900 series.
Well, you can 'change' them but it has no effect in reality. The voltages are controlled entirely by hardware on the card.
