Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Anyone heard of a way to get custom MP3's into the soundtracks for Underground 2 like you could in the orginal? The stock songs are really beginning to blow.
Use Goldwave and start recording via the "What U Hear" setting...
Start the game and turn off ALL sounds (just turn the volume sliders all the way down) in the Audio thing...
Go into the Tracks thing and click on a track and listen to it all the way thru...
U now have 1 of the songs...
Click on another song and listen to it while Goldwave continues recording...
OR u could Alt-TAB after a song is over and stop recording and start recording a new file and go back into the game and click on a new song...
Then after u have all the songs just edit out the mouse clicks or maximize/minimize sounds or whatever that occured before and after each song and then ur done...if u didn't Alt-TAB then u have one long mp3 that u can just copy/paste into new windows within Goldwave and save them as seperate songs...
I don't know of a music extractor like in the first game...don't think there IS one...this is just the long way (and maybe the only way with the exception of audio editor preference)...
THANX
C'YA
<---- Well as you can see, I am blind...I MUST call that eye doctor of mine before it becomes permanent...(sry bout that)...
Anyways there is NO way of importing mp3's...PS2 and PC have to be exactly the same since they both play together online...u can (or will be albe to) mod on the XBox version tho...fecking lucky ass bastards!!!
