NFS:U2 Where does it save the game??
Ruffian998
I'll be reinstalling windows here in a few days, I would like to save my progress that I have made in NFSU2. My question is, where the heck does it save everything to?
Thanks in advance.
I quoted this from someone i don't remember now. I saved it as text and just use it remind myself where i should look for to restore or backup my NFSU2 saves.
"You must enabled Hidden Folders. Go to Folder Options > View > "Show Hidden Files and Folders".
Save Profiles Location:
C:\Documents and Settings\[PC Login ID]\*Local Settings*\*Application Data*\NFS Underground 2
Note:
[PC Login ID] = The USER ACCOUNT in your computer which you MADE the save file not just in any user
* = Hidden Folder
Theres Should be a folder called NFS Underground 2 there."
its not there, I found the one for the original need for speed, but not for that one....
It's there, you aren't looking in the right place.
Application Data is a hidden folder and most don't know where it is. You have to find it.
I was in application data, its not in there, I dont know how else to tell you that. I keep it so it shows hidden files and folders as default....
Just double checked mine (show hidden files and folders)
D:\Documents and Settings\Cyprus\Local Settings\Application Data\NFS Underground 2
(my windows is on D: )
yeah my windows is on D as well. I guess I'll have to start from the beginning again.
