NFS:U2 Screen Resolution question
djnes
I loaded this game last night to play, and I found I could only select up to 1024x768. I did a bunch of searching, and found a little app for Most Wanted that let's you specify a custom res. Does anything exist for Underground 2? How about a config file that I can edit? I want to be able to use 1280x1024.
Hmm, I can play the game at 1280x1024. It is in the options for me, weird. I have not seen a program like that though.
I'm wondering if this is a new option with a latest patch? I installed the game from CD and started playing.
I have not patched up the game. I do not have internet at the moment and I have just recently gotten the game from a friend.
Mine out of the box, will only go to 1024x768, and it's running on the top system in my sig, that has a 6800 card in it.
I wish I have had an answer for you, but I don't. Have never had a problem with resolution in that game.
I'm going to apply the patch because it lists the 6800 and says it gives a performance increase for my card. Who knows...maybe this will fix the problem.
I installed the patch version 1.2 and lo and behold, I can now choose 1280x1024.
