nForce3 Detecting Array
nowei
I have a Sempron 3100 w/ a DFI LanParty UT board and if I push the FSB past around 235~ MHz, I get the nForce "Detecting Array..." message right after post but before bootup, and then the system reboots. can't really figure out why it says that since this board has a SATA lock. Anyone have any ideas?
THanks
you need to use the SATA ports on closest to the processor. those are the only ones that have the lock on them, IIRC
