nForce3 150 chipset vs nforce 250
XeRo_Dark
I recently ordered a Gigabyte K8ns pro motherboard off of newegg it was supposto be the nForce3 250 chipset, instead they sent me the Gigabyte K8n nforce3 150 chipset motherboard, i spoke to a sales rep from newegg on the phone about the mixup, and it had been over a mounth from when i originaly ordered it, and said they cant do an exchange since my recept says the K8n pro instead of the K8nS pro mother board....
so i can ither sell it and re-order it, or i can stay with the motherboard and live with it...
The box has only been opened once to photograph the motherboard, to post on a site and has been sitting on my desk ever sence, and ive yet to use it. (gay finantial problems with having enuff cash to order my cpu.)
so really what is the diffrence between the nForce3 250 and the nForce3 150 i already noticed from the manual that the max fsb it will support is 800mhz, so since the athlon 64 3200+ im gonna order has a 1600mhz fsb, and with this mo-bo it won't run at that, though ive yet to test if it can or will. any thoughts?
only big diffrence it that the 250 has a faster HT bus
and 2 more SATA ports i think the 250 has PCI and AGP locks too
the 150 has a 600Mhz(1200Mhz) HT bus
and the 250 has 800Mhz(1600Mhz)
i have the GA-K8N Pro and i love it it runs fine and over clocks well
just get the latest BIOS and your set
oh alomost for got both acan use DDR233, 333, and 400 ram
but if you put some DDR500 in there you can get the CPU to 2.5 of your lucky
and get a cpu that overclocks well like a 3000+
well most-likely im gonna buy a athlon 64 3400+ or a 3200+, and some PC3200 PQi turbo memory that has 2-2-2-5 cas latency (1024mb's), only for $226 on frozencpu.com. im very much looking forward to the new ram and new system, more-then likely gonna go watercooling so ocing will be a possibility. anyhow thx for the advice dood :D
Supposed to be???
Did U do bad research and order the wrong thing or did they send the wrong thing. BIG diffrence - if they sent the wrong thing ask to talk to the manager. If U ordered the wrong thing well....
