NForce2 Network (Code 10) Pissing Me Off!
Qwertyman
2 nforce2 boards, same problem. i have an nf7 and nf7s-v2 board, and both have come down with the ill-fated code 10. device will NOT start for some odd reason. It could probably be a bios problem but i really have no idea. If you go into the device manager and look at network connections you will see a yellow circle with an exclamantion point and if you click properties it will say device is installed but will not work properly CODE 10. I can't figure it out for the life of me. HELP!
Microsoft's website will give you an explanation of what a Code 10 error is.
Just to make your life easier, I found the link with all the error codes, for your reference.
Basically, the drivers didn't install correctly. Attempt to reinstall them. Hope this helps.
Dark Assassin
well i ran it off the cd, and i think i fixed it by downloading the drivers, i've yet to try it on the nf7 i have only on the nf7v2 and it worked. Don't really know whats causing the problems either. really weird. It worked one day then the next nothing.
always found the forceware drivers to be kind of finicky, just the price you pay for a nice board
