nforce2 drivers
jonats
NF7-S nForce Chipset Driver for Windows 2000/XP Released Date: 2003-02-21 (www.abit-usa.com)
ftp://ftp.abit.com.tw/pub/download/drivers/nf7-s/chipset/2003-02-21/NF7S-win2kxp.exe
Windows XP / 2000 - Unified Driver Version: 3.13 Release Date: November 3, 2003 (www.nvidia.com)
http://download.nvidia.com/Windows/nForce/3.13/nForce_3.13_WinXP2K_WHQL_english.exe
has anyone noticed any difference between the two?
which one is suggested that I install?
one is from abit and one is from nvidia
( I'm using an abit nf7-s rev2)
jonats,
The nForce driver kit from Abit (based on NVIDIA's older 2.03 drivers) is at least two WHQL versions older than the current 3.13 version that NVIDIA offers. But be careful if you're using one of the NVIDIA GeForce series of video cards: The NVIDIA 3.13 nForce drivers kit will install the 52.16 ForceWare graphics card drivers, whether you want them or not - and you cannot 'downgrade' to an earlier Detonator graphics driver version.
Your best bet, if you have an older GeForce card such as the GF4 Ti 4200, is to use version 2.45 of the nForce driver kit.
i have a geforce fx5200
i dont like the sound of that
i would perfer to install the video drivers seperatly
So open the 3.13 with winrar and remove the video driver folder.
Install and you have your own homemade driver package. :D
What if you have an ati card and you've already installed the 3.13s? I downloaded them off of nvidia's site and installed them and I've been having problems with my setup. It's been a small lag hit and its just a small glitch it hits for say 1/4th a second and then it goes again. Makes it a bit jittery for gameplay and I can't stand it. Thinking this could be my problem.
Is it possible to do it? and it will work ok!?
cause I am about to format my comp, and I have ati card, so to do that or just to use the one from abit-usa.com!?
Yes, that's how I do it. In fact that's the only way to do it if you want conflict free drivers especially 'if' you have a graphics card like ATI and another sound card your using (not using soundstorm). You just download the driver package - then unzip it, the navigate to where you unzipped it to (I just make a folder called C:\Unzipped) then delete the display and also the Audio folders (if you have a stand alone sound card). I also delete the nVIDA IDE folder (I still use the microsoft default) and say 'no' to vNIDA SW driver install. Anyway, once you have deleted the appropriate folders from the unzipped driver package just run the install icon (setup) from within that package.
Be careful if you don't install what NVIDIA calls "IDE-in-the-box". On some of the nForce2 motherboards, if you don't install that feature (which is basically a modified Microsoft IDE driver that's been updated to correctly identify the native nForce IDE controller), your IDE ports will function only in PIO mode under Windows XP - no DMA busmastering at all whatsoever, nor will there be any way whatsoever of enabling DMA transfers. And deleting the IDE folder will only ensure that "IDE-in-the-box" will not install.
As for the NVIDIA SW IDE driver, you don't have to install that - in fact, do not install the SW driver if you're using more than one optical drive in your system.
Originally posted by E4g1e
In fact, do not install the SW driver if you're using more than
Why do you say that? I've got a burner, and a DVD burner, haven't had any issues. *checks* Both channels have Ultra DMA enabled.
Mee too. I manually check anyway for DMA and all is ok. However I do understand where he is coming from - because with the older "unmodified" MS in the box drivers I did not get DMA and had to manually toggle DMA. Really you can just say "no" to nVIDA SW IDE drivers - you don't really have to delete the IDE folder - that is just a cautionary thing. I don't delete it anymore because just saying no is enough. But I do delete the Audio, and disply folders.
Whenever I'm installing nForce drivers on a system that uses an ATi video card, I make sure to first uninstall all ATi driver software (display drivers, control panel), then uninstall any nVidia software. Then, after restarting and letting Windows re-detect all of the hardware (and subsequently restarting again when it's done), I install the nForce drivers, restart, and then reinstall the ATi display drivers and control panel (and then restart one last time). Really not as bad as it sounds, and doesn't take long at all.
Unfortunately, the SW drivers didn't work correctly for me. When the SW drivers were installed on my system, neither my DVD-ROM drive nor my burner could even read audio CDs, let alone play them - and my burner was incorrectly recognized as "52" when it should have been "52x24x52".
What if you are doing it from a fresh format. I did windows xp, sp1, mobo drivers, then ati and I've been having studdering graphics.
I just install the nForce drivers, I never realized they had display drivers integrated, haven't had any problems so far. I haven't had any issues with the IDE drivers, but I never update drivers, I format every 2-3 weeks. Before I do it, i check for new drivers, si I'm pretty much always using the latest drivers.
If doing from a fresh install you can uninstall the nforce2 drivers, then run driver cleaner (on the nforce2 chipset) before the reboot (don't delete ATI driver yet) then reboot, install your nforce2 again, then uninstall ATI (be sure to uninstall the control panel first - no reboot yet, the uninstall the driver (run driver cleaner again but this time on the ATI driver) - then reboot, then load ATI drivers again, set refresh rate. load monotor specific INF again (so you don't have default minitor listed instead of your actual monitor). This method is a bit different than ones you might see at amdmb or nforcers HQ but it works like a charm for me, and on more than one make of nforce2 board.
