Nforce2/AMD cpu trick...
Originally posted by Grammar Nazi
the reason is to reduce total heat output, if you live in a confined space and your computer is heating up the room.
Those two do apply, but I also run F@H, so this trick won't help me in the least.
Originally posted by MrFace
buttom. Now, click on the two digit number where it says "HEX", and change it to 1F (The Hex for Offset 6F would have previously been 9F, 8F or something else). Hit Set.
Your idle temps should now start falling.
You would have to do this hack/tweak everytime you rebooted your computer if it wasn't for WPCRSET.
- Go to directory and run "WPCRSET.EXE"
- Look at the top of the window: Enable select "Start" and make sure Device is on "enable"
- Then click Add. Enter 6F for the register, and 1F for the data
- Click Ok and you'll be prompted to restart.
Once, you rebooted, open WCREDIT again and see if the 6F register is still on 1F. If it is, then that's it..You're all done."
After I hit set I hit okay to change register since this guide said nothing about it and I got a high pitched noise going through my headphones so I said $#(@ this I don't know why this is anyone have any ideas? I did finished the steps up until it said set then okay.
Anyone? I want to do this but kinda freaked if this is normal.
