nForce Southbridge - what is built in?
drizzt81
HI,
I was wondering if any of you guys knew whether the Firewire connection on the nForce 2 Southbridge is hooked into the PCI or whether is has dedicated bandwidth?
i.e.: might I be PCI-Bandwidth limited when copying something from my SATA HDD to a firewire drive?
erm, depends - what is your motherboard? Does it have the MCP or MCP-T southbridge?
if it is the MCP chip your firewire is controlled by an addon chip thru the pci bus - limiting you to a theoretical 133mb/s (prolly a lot less depending on wether or not you have pci cards installed)
According to the nvidia site and the initial review, by Tom's Hardware, of the Nforce 2 chipset, the MCP-T has firewire incorporated - bypassing the pci bus...
link to info:
http://www6.tomshardware.com/motherboard/20020716/nforce2-08.html
voila! there is your answer...
But either way the limit of the firewire may be hit first - unless you are saturating your pci bus with other uses ....
Umm NO.
PCI bandiwth = 133 M Bytes / sec
Firewire Bandwith = 400 M Bits / sec, also known as 50 M Bytes / sec
So even if it is through the PCI bus, it will not be limited by the PCI, it will be limited by the Firewire.
Besides few hard drives get close to even the 50 M Bytes / sec of Firewire in actual sustained throughput. (though a few can now)
==>Lazn
I have an Abit NF7-s (ver 1.xx) and an Abit AN7 that I am connecting via FW.
The NF7 is in my server and has a RAID-1 array (yes mirrored) with my data sitting on the SATA controller (pair of Samsung spinpoint P80's).
I am trying to improve the throughput to my workstation (AN7) which is connected via FW. At this point, I get xfer rates of up to 20MB/s, which I would say is a little on the low side, since the theoretical FW limit is ~50MB/s.
I am trying to figure out whether the speeds that I am getting are 'ok' or whether there is something amiss in my config.
I tested the throughput very scientifically:
I copied a file and looked at DUmeter... target drive was either my 36GB raptor or the 1200BB on my AN7 machine. Windows file sharing was utilized and I copied a 250MB file.
Originally posted by Lazn_Work
Umm NO.
==>Lazn
well, if it is PCI, there are other devices sitting on there and they will have to share the b/w. Since the SATA controller is on the PCI bus and those where my source/ target drives, they might well hit the limit (I do not know whether the SIL controller is smart enough to stripe the reads on my RAID-1 array)
I really doubt you are hitting the bandwidth limit of your PCI bus, but anything is possible.
By saying you are using windows file sharing, that implies you are using IP over Firewire. This adds some overhead to the Firewire bus.
And IP it self is not the most effecient, over ethernet you rarely get over 65% of your bandwidth. (say 100Mbit, so 12.5MByte, 65% of that, normal ethernet will usually give you 8.12MByte/sec)
So if IP brings you down to 32.5MByte/Sec and the overhead lost by tranlating it to a firewire bus brings you down to (guess) ~30MByte/sec, to get a real 20MByte/sec is not too bad.
I think realistically the only way to speed things up would be to go to Gigabit Ethernet ($50/adaptor + Cat6 Crossovercable = $125 ish) Then your PCI bus WILL be your limiting factor.
But I could be wrong, it has happend before.
==>Lazn
==>Lazn
that is a good point.. I was/ am thinking about GbE.
I decided to get a FW cable ($7.99 with a spiffy blue LED) was a cheaper investment in the short term. I wanted to see if quadrupling my theoretical BW would improve my transfer speeds (and it did, since it about doubled my xfer speed). I thought that if my speed would not improve, it'd be a sure-fire indicator telling me that there is no point in moving to GbE. Now, I am still not sure if it makes sense to switch, since the performance gain was not as big as I would have expected it.
Anyways, I will try to do some more research. Maybe I should -temporarily- create a ramdisk on each PC and xfer files to/ from that and see how fast it goes.
so i did my homework: voidedwarranty had a review of FW network using a third party software. They benched it with a free tool and got 125Mbit/s... reading the forums, I saw someone with winXP-winXP connection getting 166Mbit/s.
I am getting ~200Mbit/s which is what I should expect, since I found out that the 400Mbit are divided into up and downstram (full duplex).
this gives me a theoretical limit of 25MB/s... getting 20MB/s is therefore a good, realistic number and i would assume that I could get even better xfer rates with GbE.. maybe I will invest the money after all.
