Nforce question
Blast3r
I was going to order some dual channel memory off the interent. I have a biostar m7ncd motherboard with nforce2 400/mcp chipset. On the site I was going to order from I seen a chipset selection. There was nforce2 200something and spp.
1st ? Is the spp same as mine? or is mine newer?
2nd? Does my mainboard even support dual channel? Ive been told it does but I am just checking before I order some ram.
The M7NCD (400 + MCP) doesn't support dual channel memory. The versions of that board that do support dual channel are the M7NCD PRO and M7NCD ULTRA.
C.B. is right the standard M7NCD is not dual memory bus (so the memory sticks can be of different sizes - 256 mb 512mb etc.)
If it is the M7NCD Pro or ultra - you do not have to spend the extra $$ on specific dual channel memory pieces - all you ahve to do is buy the same brand, size, & spec - I got two peices of kingston ram 256 - same model not high end matched sticks like the dual memory packages - runs fine
Now if you are going to overclock - including your ram, then the extra cost of the matched pair may be worth it.
as for the nforce 2 200, spp stuff, yeah yours is a newer chipset. if not overclocking look for ddr400 as the cpu bus and memory bus will match (supposedly improving performance...) if overclocking go higherspeed lowest latency you can afford.
Right now I am running the corsair valueselect 256 pc3200 and It doesn't cut it. I seen that deal on dual channel and I thought a may give a whack at it but I think Ill just find a 512 stick of something and sell my 256.
