nforce firewall
uvi
I have an MSI K8N Neo2 Platinum motherboard, which means i also have the nvidia hardware firewall on one of my nics. Now i have that nic currently connected to the net, and am just wondering do i even need to enable the xp firewall system? Since im running xp64-beta i cant install any nvidia or msi drivers to give me access to the internal firewall (although the new xp64 firewall seems to work well). But for the sake of precious cpu cycles i would of course like to disable the xp firewall. With no ability to configure the nvidia version, i just wanna make sure its actually active. I suppose if i run into problems with program access ill have to switch nics or disable it in bios and go back to windows based so at least i can interact with it.
Btw, is there a difference between the nforce 3 250 and 250gb?
the firewall controller is a part of the nforce drivers, but you have to tell it to install that feature
until then the firewall is off
and even then, the firewall acts as a complete firewall, so not even sharign across a netowrk will work unless you configure the ports to allow it
