InorganicMatter
- Oct 19, 2004
I'm building a storage server, and the nForce 570 gives me six SATA ports all on a single RAID-5 capable chipset. It's very reasonably priced as well; with the AMD price cuts and currently inexpensive hard drives I figure I can get a really cheap file server.
I want to use 400GB drives. In RAID-5, I will have six drives, with one lost to the parity, leaving me the equivalent of five 400GB drives, or a max of 2TB. Max. That's my question: does the nForce 570 SATA RAID controller support volume expansion? If I start with three 400GB drives, can I add more once I fill up the array, and expand the array onto the new drives? I know you can do it with high-end controllers, since we've done it at work with $500 Adaptec controllers, but I need to know if the el cheapo nForce RAID controller supports this feature.
Thanks in advance.
Thanks in advance.
