I was just curious...so I thought I would ask. It maybe a noobish question but here goes
. Does the nForce 4 chipset support 2 RAID 0 setups on the nForce controller? Or are you forced to run one RAID 0 setup off of the nForce controller and the other off of the Sil SATA/RAID controller?
Configuration would be:
1. SATA 1+2 = RAID 0 WD Raptors
2. SATA 3+4 = RAID 0/1 Seagate 7200.8
Just curious because I was planning on running either 2 RAID 0 configurations or one RAID 0 and one RAID 1 and wanted to run them off of the same controller. I figured it would be easier to set it up that way. Is there a performance penalty with running 2 RAID configs off one controller?
Sorry alot of questions but I have to know this before I decide. Either way i'm tired of VIA chipsets...I think I'll stick with nVidia from now on....
