Nforce 4 Problems?
Faction
The Chairman
hello all,
I have a Maxtor MaXline Plus III 250GB hard drive 7200RPM and 16MB Cache
The performance between this drive seems to be slow.. but i never questioned it.
ran PCmark and got a score of 300 on the hard drive.. way below where it should be..
So I figured maybe I didn't have the nForce drivers installed.. so I downloaded and installed, ran the test again, and same results.
My motherboard is an ASUS A8N5X. (nForce 4 Chipset)
The drive is an IDE Drive.
Any suggestions as to what may be causing this? solutions? Thanks in advance.
Edit:
the primary drive the (250 MaxlineIII running at 14mb/s) my 60GB Maxtor which is slaved, Running at (50Mb/S) whats going on here????
well I got the rate up a bit, for some reason the drive was not set at ATA133..
Thanks.
But I don't know if this is normal or not for a primary drive on HD Tune the transfer rate is never steady, it goes 55mb/s then 35mb/s and the entire thing curves slowly downward. average speed being 40mb/s. normal? not normal?
Well, I have the same mobo....I also have the 6.65 nforce chipset that came with the mobo cd installed...Also I went with the nvidia ide drivers over the xp native set....Ummm, I never really noticed a performance slowdown, but of course since reading your post, now i am all paranoid hehe...Well, just ran the benchmark speed test that comes with the software drivers loaded into device manager....I get around 57-60 mbps which does seem kind of low for a sata drive rated at a theoretical 150 mbps...So I dunno..can u tell me what u are getting on the speed test....thanks
BTW- I am getting burst speeds of up to 108 mbps though, but sustained speed is what is important....
the interface is rated for 150mb/s (same as the SATA300 interface is rated for 300) but the drive mechanics can't get close to that.
55-60 is about right for continuous transfer for a single drive
yeah the max is like 60 but min is like 30 and it seems to jump up and down a lot on the primary drive, but not the 2ndary drive even with background applications closed.. you think this is normal? what did your test look like ? Very spiky? or pretty linear?
from what i can tell this isnt normal.
it does seem a bit slow. I get a min 32.9mb/s, max 62.5mb/s, 50.6 avg
Maxline III sata 300gb drive, nforce4 board
have you tried it all by itself on the IDE cable??
no i hadnt tried that but i have tested the other hard drive which had no problems which leads me to believe its not the cable, its not really the fact that its going 10mb/s slower than yours thats bothering me.. its the fact its so spikey.
Well using sisoft's brand new lite version, I managed to score fairly good for my sata drive I guess...here's a pic..Faction, you should try sisoft, because u can choose different drives that are similar to yours to use as references....Just in case you didn't know...Good luck...
Thank you for this suggestion but it just appears to be doing more of the same.. lower performance than other drives as well as choppy!!!! what can be the culprut for it being so choppy???
