Nforce 4 installation
Maestro
I need to update my chipset, but I can't find installation instructions anywhere. I used to use VIA so I was just wondering if the installation is simply to open the new installer for the Nforce 4 chipset or do I need to uninstall the previous version first. I seem to remember with VIA it just installed over the previous or deleted the previous version automatically. I can't remember. Thanks.
Nvidia unified drivers are pretty straight forward im my opinion. Basically istall over the previous install and everything should work honkey dory... but I have had some issues with older nforce 2 boards and newer driver packages via the onboard networking chip.
just my 2c tho :)
