Is anyone out there using a Nforce2 chipset with intergrated video? For some reason I have tons of problems when using PC2700 ram with video glitches and crashes, and it works fine with PC2100. I'd much rather use the PC2700, since it's higher capacity. I have 2 of these boards at work, and both are having the same issue with the PC2700 ram. Here are the relavant specs:
Asus A7N8X/VM400
Corsair ValueSelect PC2700(2 x 512MB) 2.5-3-3-7[SPD timings]
Windows XP
The bios doesn't have ANY settings for ram configurable. This is really starting to piss me off, because the comp will reboot when I have a nice load of things open. It usually will crash when using something video 'intensive', like WMP or other fast motion video. Does anybody have any ideas on how to fix this? I'm sure a discreet AGP card would work, but I'd rather get the onboard video working right since I have nearly zero budget.
Asus A7N8X/VM400
Windows XP
