NF7 v2.0 Help - Mobo death?
Deadly sk1llz
Well, I think I just bit a hard bullet;
Seems my mobo will not respond to me anymore. Backstory:
Last night, me and some friends were playing the BF2 demo online together (through a LAN on a cable modem), and we played until about 2:30 or 3am at night. We stopped, and I made the mistake of leaving my computer on. Pretty sure this is the reason it died. I woke up at around 10:30 this morning, and I look at my screen. Black with a flashing light on the monitor. I thought this could be sleep mode, as it likes to do it, even though I set it not to.
Move the mouse. Nothing. Tap on the keyboard. Nothing. So, I decide to reboot. Then I realize, it's not beeping when I reboot. I try a hard reboot (turn off, unplug power, replug it, turn on). Nothing. Now I'm starting to swear.
I opened up my case, and looked around, all capacitors on my mobo and my video card (set up in in sig), seem to be fine and dandy. I blow out some dust, just for the sake of keeping it sort of clean.
Then I went through, took out all components, to see what would be the origin of my problems. Ram, videocard, IDE cables, everything removed but the CPU and power to mobo. No beeping, no boot screen. I try another power supply, hoping that it was just a bad 12V rail line, and that maybe I could just pick up a new one. I tried my friend's Antec TruPower 430V PSU, so a very good, reliable one. Just like before, all the fans turn on, the hard drives spin, the DVD drive spins, everything boots up as normal, except there's no boot screen, no beep, nothing from the mobo.
This is the point I notice that the mobo fan (typical for a nForce2 mobo like the NF2) isn't spinning. I flick it a couple times, then it starts to move finally. This worried me, as I thought it could prove to be power still. So I moved on and tried to flash the damn thing, hoping that it would reset everything. In my mind, it could be the overclock that I had put on the CPU (It's 11x210, or 2300mhz right now). There usually is a special process that the BIOs flash does. You use a jumper, and move it over one pin, press power. Then it should turn on and then shut itself off once again, showing it's completed a successful flash. Now my computer does none of that, it just turns on and stays on. I wait for a while, then turn my computer off again.
Now I'm stumped. I checked power, the seating of my CPU (according to my HSF, the thing shouldn't be able to move AT ALL), components that could possibly screw it up, videocard burn outs, smelled for any sort of burning smell such as silcon to see if I messed up my CPU, and all of this turned up nothing. My last possible idea is that my motherboard, while being left on overnight has I have done with so many other games (Far Cry, World of Warcraft, Everquest 1, Half Life 2, Doom 3), decided it did not like EA games and decided to kill itself, in a seppuku-style death of gutting the very backbone of the computer.
Any other ideas, suggestions, or hopeful rays of light would be nice; but if the mobo is dead, just tell me, so I can cry now, and buy a new one for my aging computer. Thank you in advance.
... mmm k turn on ur puter and wait a bit like few seconds then turn off by holdin front power button for few sec. After that, turn off ur psu unit and tap the power button on the front few times. You will see the fan spinning for 1 seconds which clear out the electric left inside ur mobo and other components. Now turn on ur psu unit and boot ur puter up in normal way. Hope this method work, I have seen this problem with my friend before.
I tried the power on, off, turn off PSU, press power button, turn on PSU, power on, and it didn't work.
Like always, all fans turn on, the mobo light turns on, but there's no boot, and no beep.
Disassemble all of ur compnents then reassemble all of it again. Hope this trick help lol.
Edit: play with ur puter until it get to work.
Dont' worry, I've already done that. =P
Yah, it's starting to look grim.
Interesting development:
I tried using my friend's Antec Sonata case PSU ( a 430W Truepower one), and it worked! I got a number of beeps, at least telling me I have an error. This is good. However, I noticed I did not plug my CPU HSF into the power, so I turned it off and did that. Now I do not get the beeps anymore.
My PSU was from a Antec case, so it's a Antec PSU, 350W. This case is around 2 and a half years old, so could this be the culprit? The older PSU is failing, so the 12V rail from the PSU is too weak to support a full boot?
