NF7-S V2
Best? Depends on your definition of best. Include more info, what are you going to be doing, are you overclocking, are you seeking low-noise computing, are you looking for the best value? You can't be so vague with your questions. ;)
Best performance (stock) = AthlonXP 3200+
Best performance (overclock) = Mobile AthlonXP 2400+, 2500+, or 2600+
Lowest temperatures = Mobile AthlonXP 2400+, 2500+, or 2600+
Right on.
TheGamez hit it on the nose.
I'd get the 2500 mobile and OC the crap out of it! :)
i like to be different.. get the 2200+35w mobile.. cause it will still overclock like a beast.. but only cost about 75% as much as a 2400+ 35w, or a 2600+ 45w.. but it will definitely clock way over 75% as much as an average oc on those other chips.. probably 95% as much.. really it is impossible to figure that out casue overclokcing is a crap shoot..
that's just what i think though..
really ou can't go wrong with any mobile a-xp
My friend has an nf7v2 and his 2600m is at like 2.55 or something on a dumpy hs.
I almost want to get one of these boards to see how high i can get mine.
