NF7-S v2.0 question
Catsonar
If while replacing a heatsink on the mobo, and My srewdriver slips because of the dam clip of the socket, and scratches the mobo and now doesn't work, can I send it back to Abit or will they not take it. I can't believe that this has happened, i'm so frustrated, is there anyway to repair this mobo. Plz help everyone I really would not like to have to buy another mobo, I can't believe what happening
Your damage=violation of warranty=you're fuxx0red..You could always try to RMA it, but that wouldn't be very honest, now would it? (read: fraud). The clip on my SLK900-A it tight as hell, and I used questionable tools, but it has worked fine through multiple install/removals over the past year..The key is *take it SLOW*....
Just chalk it up to a(n expensive) learning experience and try again.
ps - ABIT might not even take it - a scratch on the board is different from say, mysteriously having a 'fried' board...I wouldn't want to try that if I were you, spend the $$ to get it shipped to ABIT, just to have it returned b/c they see the scratch.
Dam it, then does someone have a NF7-S that I can trade stuff for.
